MG5 SOH
Remember it’s a best guess by the car.
The only way to be sure is several deep discharges and full charges
My range shows 239 but my soh is 95.6 or something
It hasn’t made any actual difference to the range I can drive
So how deep discharge are we looking at what is the % to stay with in
I run mine down to well under see 10 percent and give it a full charge every six months or so ( as instructed in the manual)
See what energy it takes minus 10 percent
Then compare that to car scanner
Otherwise I use the distance displayed at 100
Or car scanner
Honestly though if you worry about it you will tie your brain in knots :) (I did)
Frankly it’s still a bit of a best guess
Or car scanner
What page is this described in the manual
I took my 74 plate trophy down to 7% then charged up to 100% and it took 60.42Kw just over 2 weeks ago you could see it balancing the battery’s it must have took 15 minutes when it was at 100% at various rates 4.4 3.0 1.2 0.6 etc.
Mg 5 2021 3% to 100% 58.4 kw now i have a smart charger and plan to check capacity on car scanner and then add 10kw to see what the losses are when charging.
I thought the 10-100% was just for the MG4 LPF batteries
Below extract is from the MG5 manual (HV battery maintenance)
Car scanner shows i still have 100% SOH, I've just past 30,000 miles.
I'd say less than 15 blasts on a rapid charger with the rest charged at home 7kw.
I took this after a 12 mile drive, when I got to work, started at 92%.
2021. It's the last of the standard range.
OK, that rings a bell, can’t remember where I came across this, but rumour has it that some SR have been equipped with ‘rejected’ LR HV battery packs, meaning they will basically stay @ 100% SoH for years..
I thought they had LFP batteries whereas the long range had NMC?
