MG5 Speed limit warning
RTB
MK
Traveling on duel carriage way at 65mph the little speed sign top of pilot on the left flashing 30 then going to white back ground with black strip running through, what's going on?
It's reading road signs. But sometimes it misses them. When it's flashing it means you're over what it thinks the speed limit is, so when you were doing 65 it thought you were in a 30 zone. Then it saw a national speed limit sign and it's happy again.
Thank you for all your replies
The white circle with the black diagonal is the National Speed limit sign (you should know that) it’s flashing as you are over 60mph which for some reason the car thinks is the speed limit for all National Speed Limit roads even though it’s 60 or 70 depending on road (50 if your towing)
One thing that I find annoying about the speed limit warning - it tells you the speed limit just as you're leaving that zone! e.g. 30 mph going into 50 mph, just as you pass the 50mph sign, it will say the speed limit is 30. Mine is a 21 reg MG5 Standard Range (bit of a dinosaur now).
