MG5 SR charging display state order.
Jomarkh
Distinguished Member
Southampton
MG5 Excite
I thought I would use the 'granny' to see the different charge states the car displays.
At 97% car is 'in charging'.
At 100% car has 'finished' charging but not turned off the EVSE so 'not' balanced.
When the car is balanced it shows 100% connected 'uncharged' and turns off the EVSE.
The car was unlocked for this but if you open the door the display comes on.
Interesting pics because as I sat in the sun today I was thinking whether I ought to stick the car on the granny to use solar excess ( - I don't have loads of spare as I only have about 4kW of panels, so on the granny it may stay within spare capacity). Your pics sort of confirm a figure I thought I'd seen, that it would charge less than 10 (I recall from somewhere about 7 mph).
I can see from the IHD when I am importing and exporting but have no way at the moment of turning a switch on and off accordingly. With being on the 5p Go Faster (20:30) rate I wouldn't really want to risk putting too much in at standard daily rates, though I can manually switch the socket remotely through my Home Assistant - could do it automatically if I had real time data, but I am not about to spend loads to enable that.
I suppose with the Home Assistant I could avoid temporary blips by, for instance, automatically turning off the plug when the kettle goes on, and turning the plug off at maybe 5pm when even on a good day production slows. I do have a light sensor so I can also turn it off it it goes suddenly rather dark but that doesn't help if someone turns on the oven. Food for thought...
Thanks, very useful ?
Thanks for this.
So you don't get a picture on the display of a black car then?.
I didn’t realise I had roof bars either?
I suppose it has to display 'uncharged' as at that point it has turned of the EVSE.
