New Cyberster Owner - Drive to Switzerland
In my view ABRP is a must. Linked to a Bluetooth OBD2 I get real time range, charging locations with stall availability. All add up to less stress as I know where to stop or if I can keep going.
I read about that, but the article I saw also had a big security warning that OBDs are insecure and people can unlock the car with ease and gain entry, which immediately put me off.
How do they work? How do you hook them up to the car and to ABRP?
You plug them into the OBD2 port (just under the steering wheel) and then register for ABRP.
Then in the app register, set your car as the MG4 Long Range, and tell ABRP you want live data.
Then you’ll get realtime info in the app.
I connect my phone to CarPlay but then launch the ABRP app separately on my phone. That gives me Google maps in the car and a quick glance at the expected battery levels on my phone, without paying.
When you get out of the car, just pull the OBD2 device out of the car and stick it in the glovebox as you’ll only need it for longer journeys
Thanks for the info. I'll keep it in mind when I get my car. Kind of a shame the the built in nav doesn't do this stuff already.
@Cyberella - that’s an impressive range on the Trophy, at 70mph speeds I can only manage about 180miles @ 70mph in my GT on 100%>10% battery.
You’re only about 45 mins away from me, maybe we can do a comparison against them on range at some point (same route, same speeds, etc) to see how the cars actually compare
Isn't the range of the GT supposed to be 270 miles or so? I know WLTP is only valid in dreams and delusions, but 270 to 189 is a heck of a difference.
The WLTP test cycle has an overall average speed of only 33mph, with no heating on, over 4 phases with average speeds of:
  1. Low: 16mph
  2. Medium: 28mph
  3. High: 38mph
  4. Extra High: 59mph
Normal driving at speeds of around 50-70mph in cold conditions will never get anywhere near the WLTP range.
Only GreenNCAP do realistic range and efficiency testing - see https://www.greenncap.com/assessments/
In their testing of the MG4, efficiency ranged from 1.8 mi/kWh in very cold conditions up to 3.8 mi/kWh doing a warm-started WLTP cycle. GreenNCAP's BAB130 Highway test is a good measure of UK motorway driving range.
Sounds like WLTP is about as useful as a chocolate teapot. At best misleading if not an outright scam. Who drives at 16mph?
In my experience no built in maps are any good.
They are an example of how behind the car industry is in innovation, the same way some traditional manufacturers were still installing CD players.
CarPlay and android auto is so much better.
The only exception is Tesla but they only show their chargers and block CarPlay (they did the last time I drove one) so you are stuck.
@Cyberella. Great and informative post. Regards comments above, yes, WLTP figures are pie in the sky and it is not uncommon for real world ranges to be at LEAST 100 miles less than WLTP!
But the single motor RWD Trophy in this posting and usage case has very good range. Good enough in my opinion. The heavier AWD GT will have far worse range even though the WLTPs are quite close. This is a car for long sunny holidays and driving in the UK and Europe as shown in the original post. If the range is poor, then you never fully relax as always have one eye on the next recharge stop, and probably have to stop longer to get 90%+ SoC to get as much range in as possible.
I specifically went for the Trophy as the range is more use to me than the second motor.
I just went to Brighton, early morning, M4, M25, M23 Motorway 70mph most of the way and after charging to 100% I had 240mile range showing on the dash.
I'll check later whether coming back along A27, M27, M3, A34, A4 has made a difference.
Incidentally as I was passing Winchester I thought I would try out the new Supercharger Hub, supposedly on the A34 but couldn't find it as it's not on the SatNav, and couldn't get a phone signal to use CarPlay. No signs anywhere on the A34, but got home anyway on a full charge from Worthing to Calne (120 miles) non stop.
Just remembered something I forgot to add in my post. On the way over on the Ferry, I was getting alerts in the MG App every five minutes due to the movement of the ferry triggering the tilt alarm.
I disabled the tilt alarm on the way back so didn't get any alerts. It auto switches back on when you start the car.
