Ducks
- Apr 19, 2026
- Bristol, UK
- MGS5
I have a battery booster in the garage from when my very old Honda Civic had battery issues (turned out to be the Bluetooth for call which I never used). Will have to dig it out and check it still works...My usual advice to new owners is to sit in the car with a cuppa and a few biscuits, press the brake pedal so the car is in a ready state and explore all the settings.
Unless you need to get the maximum range between each charge drive the car how you want and if you like having the AC or heating on all the time have it on. It might decrease the range by 10 miles but that is over a full charge and if you are on an EV tariff pennies in cost.
Things to keep in the car are a 10mm spanner as @Caramaddy has mentioned, and for peace of mind a battery booster just in case the 12V battery goes flat. I keep mine in the centre arm rest so it's easy to get at. A lot of us have one but have never needed to use it apart from helping to start friends ICE cars![]()
Thanks for the advice!
