JodyS21
- Jan 24, 2021
- Location
- Milton Keynes
- MG ZS EV
It is possible that the HV battery power that you see is going to the DC-DC converter and then to the 12V system.I am of the opinion that the HVAC system uses both the 12 volt battery and the HV battery, as stated by others.
The 12 volt battery will be used for providing power to the blower motor in the unit ( the thing that provides the air though the vents ) and the HV battery provides the power to provide the heat or the cooling.
You can see this divide some what, if you have the car in the “Ready” condition and with the blower motor turned off and the heat control set to no heat or cooling.
Now - Turn on the blower motor only and keep an eye on the GOM and select the power consumption screen, by scoring though the menu’s on the right hand button on the steering wheel.
With the blower motor ONLY pulling a load, the drop on both gauges will be next to nothing, because the demand is coming from the 12 volt battery.
Now - Turn on the demand for heat to Max setting and watch what happens to the range on the GOM and the amp gauge !.
This proves that the power required to heat or cool the car IS coming from the HV battery.
You can see this when you are travelling as well.
With the HVAC turned completely off.
Firstly, check out your remaining mileage on the GOM.
Then turn on the HVAC and ask for Max heat, almost instantly you will see a 8 - 10 reduction in your predicted range straight away.
HVAC systems are a big consumer of stored energy in your HV pack.
This is one of the reasons why your winter range is never as good as your summer range.
Using “Eco” mode lowers the heat & cooling ability of the HVAC system in an attempt to preserve your range a little.
If you are running short of range while on a trip or looking for a charger, then turn off your HVAC to save your remaining range.
It doesn't really make any difference to the HV battery usage which way the power actually gets to the heater.
To know for sure, would either need to look at the heater wiring to see if it does connect to 12V system or HV system direct, or could probably tell via the OBD2 data - as that shows 12V load I think.
