Night time Screen dimming
Kegbuster
BROSELEY Shropshire
MGS5
There seem to be no difference between the
software of older model cars and new model car.
There seems to be no auto dimming of the screen at night a very bad safety issue!
Why is this?
It is a real nuisance!
This is the only thing which gets my goat with this car since I bought it in May
Why is this?
As mentioned on another thread, to set the night time level turn on your headlights and set your preferred screen brightness. Now when your headlights come on the screen will change to the level you have set.
If that is still too bright swipe down from the top of the centre screen and turn the screen off.
It's a shame it can't switch to dark mode when the headlights come on, but if you use Android Auto with Google Maps that part will go into dark mode.
As the pervious threads have said dimming is still not the answer as the screen is still too bright. Surely the screen should to the black mode.
I find that having the screen in light mode but minimum brightness is okay.
I understand some will find the light theme too bright for night time lighting.
It certainly is if left unadjusted from the default settings.
I've set the brightness to zero for when the lights come on - it's just about ok for me!
I'm in agreement with other voices here - dark theme for night time is the ultimate switch that should happen automatically and should be 'set-able' in the same way the brightness is programmable already.
The only workable answer is to use the dark mode by default.
Yes, but have you seen the Sat Nav in dark mode? Almost unreadable!!! Mind you, I haven't looked again since the test drive, so may try Dark Mode again now I have my S5....
I’ve just set mine to auto, with the brightness turned down to the lowest setting. Works for me.
There isn't an auto option on the MGS5.
I notice this was your first posting on the MG EVs Community forum so welcome.
You'll find lots of help, advice and banter on the forum for the ZS Hybrid + here
MG ZS Hybrid+ Forum
I know what you mean about the sat nav in dark mode, but if you put in a destination the route is completely readable.
Thanks for the welcome i’ll try the link.
Tried the suggestions and yes it works. And yes, i do hope there's an update that changes the theme based on the light levels. I personally love both the light and dark themes.
How do you set the screen brightness on an MG4?
