Owner feedback and Suggestions/Improvements
Do you guys think reverse camera with and 360 cameras should be in the center screen not right?
Centre screen being the one with the speedo? Or the one with the aircon settings? I’m fine where it is. I would just like the cameras to stay clean!
true, all the time dirty !!
As an experiment I’ve done this using a cut to shape piece of plastic sheet and duct tape - not sure how long it will last but I can’t see anything it will affect other than keeping the bonnet cleaner.
Optional update for Chinese animations and swoosh sounds! For those that want it would be cool. Toggle option you could turn it off anytime along with sound effects and it saves the setting
Has anyone got any thoughts on the Cyberster lights when driving at night especially out of town / country roads ?. I find the high beam is very good but the dipped beam is terrible. I have the light levelling dial at the setting that covers more of the road but it is still not very good. Perhaps I was just spoiled as my previous car (Porsche Taycan 4s) lights were superb.
Completely agree! Been meaning to mention this along with the way the dash reflects up on the front windscreen in general...
It appears all the "flash of the dash" has either been disabled or they left the unreal engine tech out. There are animations as the doors open but no one is inside so no one sees it.
Are they adjustable? The MG4 has simple screw adjustments for main/dipped beam height under the bonnet near the lights but I don't know if the Cyberster is the same. Early MG4s batches had badly adjusted lights.
The adjustment problem should be easy to solve in the workshop. Just have them do a light test and correct the headlight setting. I wouldn't tinker with it myself without measuring equipment.
This was the press release SAIC MOTOR did Unreal Engine and all the Cyber OS get left out when they built the cars ?
Exactly this. At night when roads are wet, turning right into side road with no lit bollards is actually quite hazardous - you can’t tell where the kerbs are or if there’s an unlit central reservation. It caught me out several times in one journey. My RS6 switches on the fog lamp on the side you’re turning into, so like you am probably spoilt.
When will there be an option to get the steering yoke back. I would get one right away.
Would it not be nice if the cameras could be used as a dash cam. All that is needed is a software update and a memory stick in one of the USB ports.
Something like all the Tesla's have...Or even the BYD Atto 3 and Seal..
The outside mirrors positions are not saved in seat memories (either 2 or 2). I tested this with 2 different cars; you can hold down button 1 or 2 and the seat adjust to the saved position but the mirrors do not. According to the manual, the mirrors should be memorized too.
