Raymond 1956
Does anyone know how to adjust the front passenger seat. Mine does not appear to have any means of adjustment
Hello @Raymond 1956
The passenger seat is manually operated.
Yes I have looked in the manual but cannot find the adjusters
No, that diagram is for the manual driver seat which has height adjustment. The passenger seat does not have this.Hmm, interesting. I looked at mine and I only have levers 1 and 3. I assume that it must be a faulty assembly then?
Only the drivers seat on the Gen 1 & Gen 2 has electrical adjustments and can be lifted up and down in height.
The passengers seat however, is only manual adjustment and the height of the base of the seat can NOT be raised in height, like the drivers seat can.
If it's the case it's actually missing parts, then it's an issue to take up with the dealer.In the case that @Raymond 1956 describes, if I have understood correctly, his manually operated passenger seat doesn’t have any adjusters at all?
Yes that is correctIn the case that @Raymond 1956 describes, if I have understood correctly, his manually operated passenger seat doesn’t have any adjusters at all?
Could we please have a picture?Yes that is correct
No just backward forwards and reclinecan passenger set be adjust up and down on mg zs ev ? mine no handle to do it .
