Passenger seat
Hello @Raymond 1956
The passenger seat is manually operated.
Hmm, interesting. I looked at mine and I only have levers 1 and 3. I assume that it must be a faulty assembly then?
Pretty much asked and answered:
Only the drivers seat on the Gen 1 & Gen 2 has electrical adjustments and can be lifted up and down in height.
The passengers seat however, is only manual adjustment and the height of the base of the seat can NOT be raised in height, like the drivers seat can.
The passengers seat on U.K. models of the ZSEV has manual adjustments only.
It can only be adjusted in a forward to back wards movement, to increase leg room, by lifting up and releasing the handle below the seat base.
The back of the seat ? can also be adjusted to recline, with a lever positioned at the side of the seat.
The height of the base of the seat can not be lifted in any way, it is totally fixed !.
The drivers seat ? however is totally electric on the top trim level models and has the same adjustments as the passenger seat, BUT includes the function of raising the base of the seat also !.
If you do indeed have NO adjustments on the passengers seat at all ( which I find unlikely ).
Then I would contact your dealer as this is very unusual to at the least !.
I see that when you open your door the rain drips in from the roof flipping annoying ???☔
can passenger set be adjust up and down on mg zs ev ? mine no handle to do it .
Good evening any chance you can help me on how to move the passenger seat forwards? As needing more leg room for the rear seats for a baby 360 car seat to move more swiftly. Thank you
Its for an MG ZS ev
