In the boot, take off the speaker looking grill on the side by the charging port and pull the release cord.I'm stuck at work; the plug is stuck in the charging port and wont pull out. Any ideas?
what did it?Life saver thank you sorted now
Should be no need to stop the charge. Just unlock the car. If the plug is not pulled within a short time then it will lock back in again. Then you have to relock the car and then unlock it again.Assume you have locked and unlocked the car as well as stopped charging?
