?POOR HEADLIGHTS?. ??NOW SORTED??
Ian MG5
BARNSLEY
Hi all
Just did a quick rendering on how my MG5 would look with some spotlights on
I changed the bulbs - easy, but fiddly - to PIAA Hyper Arros HB3, whiter but not really much better. The problem I have with the standard lights is that on dipped beam they just don’t seem to extend far enough to see the road ahead, beyond about 8-10m. At night that’s not far enough to be able to react to anything unexpected ?
100w off road HB3 bulbs, Bright as Leds but without the Dazzle, not road legal, but who`s going to wrestle under the bonnet to check?. never failed an MOT yet ;)
Well they don't have to do they if you've admitted it? But don't worry, your confession is safe with me. And the entire internet...
Silly Question, you haven't knocked the light angle adjuster dial have you? I thought the light range was rubbish when I first got it then realised that the lights weren't self leveling and I had or the dealer had the lights set for a heavy load and at the wrong angle.
Even when correct they aren't the brightest though.
I had my car in after I did my first night drive when I noticed I was spotting planes with the drivers headlamp n lighting the curb up with the passenger side
All sorted and now running osram night breakers
You mean the one in the car, by the drivers right knee, no, I checked that's its on the highest setting.
When you say highest setting do you mean highest in range 0-3 or highest in height as they are the opposite to each other.
Without stripping down my car to take a look, which bulbs are the stock headlights?
H4, H7's, what? (please...)
I have had a lot of satisfaction from Auxito LED's as replacements in other vehicles.
They are HB3. I replaced them with LED bulbs for a significant improvement. They also passed an MOT as the beam pattern is well controlled. Now have a facelift Trophy with standard LEDs and don't see much difference
No need to strip down your car simply look in the manual. Here you go just for you.
Which lamps did you use?
I got them from Amazon but no longer have the details. They were about £50 I think
I used Osram Night Breakers as I do on every car, much much brighter, still halogen so no issues with CANBUS easy fit 5 minutes only.
I got some 'IKERY Ultra 9005/HB3 20,000Lm 6500K IP67 50W LED Bulbs' from Amazon £27.99 then, now £24.99 Pair.
They are excellent, pattern is perfect, don't get any flashes from oncoming traffic so I believe they're not blinders.
P.S. Make sure the bulb end is vertically disposed, otherwise pattern will not be correctly aligned.
P.P.S. I tried the 'Night Breakers', they're not a patch on these bulbs.
