Ian Key
Distinguished Member
I know it was just an example@ Ian Key
Who is unplugging the TV at night???
I just tell Alexa to turn the TV off which it does then turns it off via a smart socket
Can't see why you would need both on at the same time.. heating cabin for 10 mins warms up seats and steering wheel too.That explains why my heated seats where still cold yesterday then![]()
I first requested "preheat the cabin" from the App and it returned as a "OK - request successful".
Then did the same thing for the heated seats, it also returned "OK - Successful".
But the seating did not work ?.
So, it appears that the car can only process the first request you make, NOT any other following
requests, even though the App reports them as OK - "successful".
You have to decide which single feature is your major priority.
I tend to think preheating the cabin, then manually switching on the seats / steering wheel heater if required, when you enter the car maybe the best fit for the frosty glass winter months ?.
That’s a bit like saying, why would you want the cabin heater on at the same time as the heated seatsCan't see why you would need both on at the same time.. heating cabin for 10 mins warms up seats and steering wheel too.
Exactly.. why would you? If youre that cold wear a coat, saves the planetThat’s a bit like saying, why would you want the cabin heater on at the same time as the heated seats?.
The facility are there, so you should have the option ( or not ) to use them.
Each to there own I guess.
Save even more of the planet and take a busExactly.. why would you? If youre that cold wear a coat, saves the planet![]()
Would it have to be an electric bus?Save even more of the planet and take a bus![]()
CorrectHas anyone had problems with the rear wiper, it doesn’t seem to defrost/demist where the wiper parks itself? I guess that is the DAB aerial.
I have no issues with mine. I remotely switch on the heating and steering followed by the Aircon and they are all working when I get into the car. I also add the front and rear demister if I need to.Yeah mine works fine so far. You can't have Air Con and seats, its either or. If it don't work then it's a warranty issue.....
So we are doing ourselves no favours. By having EVs, we reduce global warming, meaning it's more likely that our cars will freeze up and our wipers stick.
Rear wiper? Luxury, i dream of having a rear wiperHas anyone had problems with the rear wiper, it doesn’t seem to defrost/demist where the wiper parks itself? I guess that is the DAB aerial.
This is normal, the bottom lines are the radio antennaHas anyone had problems with the rear wiper, it doesn’t seem to defrost/demist where the wiper parks itself? I guess that is the DAB aerial.
