Problem hard wiring dashcam
Droolong
UK
MG4
I have a query hard wiring a dashcam in my MG4 'hoping someone can help. I can wire into a permanent 12V Micro2 fuse socket (2 prong) which works fine. I'm not worried about the 12V going flat as the voltage occasionally jumps up to over 14V when the car is switched off so I think the MG is doing it's own monitoring of the 12V. My problem is the longevity of the SD card as its constantly writing 24/7.
I can't find a micro3 add-a-circuit fuse adapter which will fit into the switched fuse sockets F44 & F45. I bought a couple of add-a-circuit adapters off ebay (both seem to be from the same manufacturer) but try as I might I can't get them to fit into the fuse slots despite the fact that they seem the same size. The metal prongs maybe marginally thicker but fuses which look the same width slip in easily. I don't want to use excessive force as I don't want to damage the fuse box.
Any suggestions for alternative adapters, should I just accept the SD card will wear out or am I being a thicko some other way?
Which version of the MG4 do you have?
The reason I ask is that I faced a similar issue (see this post - Dashcam install), but managed to workaround it with a micro2 in the micro3 socket (if that makes sense), in order to get a reliable switched ignition source to the dashcam. That was with our SE SR, though.
As I thought, I'm a thicko, didn't find your post. I have a Trophy but I think the wiring in this part of the fuse box is the same, with my eyesight I couldn't see that only the top two holes were wired. I'll try this later thanks.
Just did mine yesterday and found that you can put a micro fuse tap on any of the sockets that are empty on the left side of the fuse bank. All that bank appear to be acc switched. All to the right seem to be permanently live.
Don't quote me on this
My son says if I put some gismo into the usb port on the rearview mirror it will record the footage from the front facing camers
MG ZS trophy connect
I have a nextbase dashcam, professionally installed with hard wire kit, I am not confident enough, it has been hard wired and as the MG Trophy does not use a start\stop switch, it is wired to a constant live connection.
the dashcam stops recording after a time with no motion detected, and starts up again as soon as motion detected. it will also start up if car has been nudged.
Did you ever resolve this? Ive got the exact same problem and the micro3 piggyback just won't fit in the fuse holder despite the prongs looking identical in terms of thickness and width and separation!
It's driving me mad! I'm usually really good with this sort of stuff and I can't figure out what I'm doing wrong!
I plugged my 2 prong micro fuse adapter into the 3 prong fuse slot. but you might need to turn it around 180 deg depending how its wired.
see my thread here for the Cyberster I don't know if yours is similar, but some other MG models are. Definitely the MG4 which the Cyberster is based on.
That's really useful, wish I had seen it before I did mine. Unfortunately my wiring kit didn't have a 3 pronged connector but the 2 prong one works ok but couldn't be used in an occupied slot. I have used F46 which is unused but has switched power, I didn't have access to the Fuse box details as shown in this clip. I emailed MG Support to ask for the manual and they said do not touch anything take it to an MG dealer, although I did tell them that I have a HNC in Motor Vehicle Engineering.
    Votes: 969 77.7%
    Votes: 185 14.8%
    Votes: 93 7.5%
