Problems with DAB radio
Exiledinwales
Swansea
I did a factory reset and have lost DAB reception, which was strong before. It will not search at all or pick up any DAB stations. Anyone else had similar? If so how did you fix ?
Possibly try moving to a place with better reception if that helps? Or you would need to go back to your dealership and seek their help.
You could try disconnecting the negative lead on the 12 volt battery, then refit it again after about five minutes.
This may reset the module ?.
You haven't fitted a dashcam or led lights anything new to the car recently have you ?
try resetting the infotainment system. With the car turned on, press the home button lever down and hold, the screen will go blank but keep holding down until you see the mg logo reappear, this will take 20 -30 seconds, this worked for me with sat nav issue, where it freezes at the start location. its the good old saying "Have you tried turning it off and on again" ;):) worth a try!
