ChrisVanRock
- Sep 19, 2021
- Age
- 58
- Eastbourne
- ZS EV
Can anyone advise .. stuck for days
See this thread Radio module replacement, the same radio issue like yours I think.Yes done that … seen the older threads … looks like I brave a 12v disconnection or go dealer .. but the dealer is always a hassle
Yep - looking like a Gen1 ZS EV to me also !.My guess is gen1?
Les , apologies MG ZS 71 plateHi chrisvanrock, can you please advise us what the car is, even your Avatar says not an MG, so sorry without knowing what the car is members are guessing and you could well get some wrong advice I’m sorry to say.
Les
I like the TF Chris, and thank you for understanding, now also when you have 5 minutes spare, please do correct you Avatar its helpful for others yeh, so now we know what we are looking a MK1 ZSev, you say you have tried the re boot, if so the only thing left is the 12volt battery disconnect, Lovemyev as described above what you need to do if you do do it.The red one not my other TF
Hi Les … thanks for the help ( love you on the forum videos btw ) …. Ok I unplugged the module connector behind the glovebox and reconnected after 10 seconds … it works a treat now ?I like the TF Chris, and thank you for understanding, now also when you have 5 minutes spare, please do correct you Avatar its helpful for others yeh, so now we know what we are looking a MK1 ZSev, you say you have tried the re boot, if so the only thing left is the 12volt battery disconnect, Lovemyev as described above what you need to do if you do do it.
Im not saying this is the right thing to be doing so I take no responsibility if something goes wrong, but can’t see why it should, loads of members here and on other sites have done this, I did it myself on a neighbours MG5, even the breakdown services use this method to try and correct faults at the roadside, be for calling for a low loader to drag you away, other than that Chris its dealer time I’m afraid to say, it’s hassle with the dealer you said, don’t know why it should be for something like this, but remember Chris you don’t have to use the dealer you got the car from, I don’t so don’t be afraid go elsewhere to a different MG garage / dealership.
Now just in case when you did a reboot the it didn’t work it is important the correct method is used which is, press and hold the large / volume button in the centre of the infotainment sytem IT IS IMPORTANT TO KEEP IT FULLY PRESSED IN, until the MG logo comes back on the screen only then let it go. Good luck and keep us updated please.
Les.
This is for gen 1 but may work
Try the 12 volt disconnect, leave 15 mins and reconnect.Anyone Know
1)if this works on MG5
2)if the radio module is in the same place
3)How to get the glove box out. It is NOT the same as the video
Thanks people
