Harry 17
- Jun 24, 2022
- Notts
- MG4 (2022-2025)
Thanks Les ??.Hi Harry17, I’m not a ZS driver I have the MG5 SR so I’m not, going to try and advise you about all the toys the New ZS has onboard.
if it where me in you shoes I would just drive it and forget about all the tech stuff for now do your journeys and get used to the car before you start turning things on and off, with regard to the Zappi best charger on the market in my book, I’ve had mine about 2 years now and I do have solar but no batteries as yet.
The Zappi does what it stays on the tin, so after your journey just plug it in set it to fast on the unit or its app, lock the car and forget about it next morning unlock the car and pull the plug out immediately, as after a very short time the car will lock itself again and you perhaps won’t be able to pull out the plug until you unlock the car again, then once unpluged set the Zappi to stop which is the off setting as well if your Zappi is not tethered type and you have to use a type 2 cable out of the car with it don’t forget to take the cable with you in case you need it but for 90 miles you won’t.
So Harry Good luck, enjoy I’m sure you won’t be disappointed with the MG ho and by the way welcome to the forum.
Les
it is through the likes of yourself, and others oN this forum, why I decided to go for the tethered Zappi. Had a drama yesterday. When I realised I would be using it, i had a little play, and quickly found we had not connected it to my wi-if . Tried and tried reading something called “the instructions” but could not even work that out ?. Anyway, got installers here around 08:00hrs today to hopefully get the wifi up and running, ready for the weekend.
Failing that, there’s is always the granny. ?
