I have a dumb Rolec unit that was installed in 2015.
I have control via an App and a Wi-Fi relay installed inside.
As the Gen1 ZS EV has no provision for controlling the level of Soc to the car and will hit 100% every time you plug it in.
You can charge close to the percentage you require by doing this.
Plug in the car and let it commence the charge, then go to the driver window and check the dash panel.
Firstly it will show your current SOC and the range.
After about 30 seconds it will then display the length of time it will take to hit the 100% full mark.
If you take your remaining range and then quickly work out, that for every hour you spend on a 7kw wall box, this will add about 25 miles of range for each hour on charge.
So, if your remaining range is showing 50 miles when starting, then 2 hours of charging from the wall box is going to give you 100 miles of range when you stop the charge.
Set a reminder in your phone ?.
It’s a bit of a “Faff” but it will offer you some control.
If you using a night time off peak tariff, this is not very practical of course !.
This is why I upgraded my dumb Rolec with a Wi - Fi relay for the cost of around £15.
Now I can set my start and stop times from my phone.
You can’t set to a percentage, but I have become use to judging the length of charge and converting that length of time, into a percentage SOC in the way disproved above.
One hour charge, equals 25 miles of added range.
