Hi, has anyone else seen rust appearing around the holes under the bonnet?
That is concerning !.
How old is your car and how many miles has it covered ?.
The paint applied in these types of areas ( which are not visible ) on all cars these days are very minimal indeed these days.
It’s almost only like an over spray, from the main painting process.
It will be a roughy dull matt finish as no protective lacquer will have been applied to save money.
The rust starts at the very edge of hole(s) because there is no paint finish applied to the edge of the holes.
Moisture enters here and It creeps under the paint finish, it can be seen appearing like a spiders web spreading under the very thin paint finish.
This is easily more visible as an orange colour under the white paint of the car of course.
Application of a rust preventative into these holes at the factory would have prevented this situation from occurring.
Unfortunately now it will need sanding and refinishing before any anti rusting agent should be applied.
Will this covered under warranty I wonder ?.
They tend to try and dismiss this type of thing as “Staining” which is total B/S of course.
Thank you for posting your findings !.
Purely on a personal bases, I would be checking my car and then applying some anti rust protection spray into each and every one of them holes, purely as a matter of course ASAP after seeing
@Jomarkh car.
