ukflyer
- Aug 20, 2022
- Location
- Horsham UK
- MG4 Trophy LR
After a few weeks of trial and error, I have found the easiest and most effective way of using the adaptive cruise control is this:
If you want to not have the car steer, but set a speed and follow the car ahead, use the adaptive cruise setting.
If you want the car to steer and set the speed to follow the car ahead, use the traffic jam assist setting.
In both cases keep the lane keep assist off!
Keep in mind the steering works best on dry roads in daylight with defined lines on each side. Wet, dark excessively curvy roads and those with patch lines can confuse it. Always keep a hand on the wheel and be ready to guide the car or take control. In fact it only goes a few seconds if you are not holding the wheel before getting angry at you!
Hope this helps and if anyone has worked out a better method, please let us know.
