Soft brakes…
stoneyev
Aberdeen, Scotland
HS PHEV
Had my MG HS Phev for a while now and wonder if any one else has issues with brakes? The pedal seems sooooo soft and I wonder if car is going to stop. Had to do a swift stop the other day and was not impressed. Glazed pads ???
My pedal is soft, don't think it's air. I have driven another identical one with the same low mileage and it was the same. Be interesting to see if other owners are experiencing the same issue?
Yep- I sometimes think it takes a bit to stop it. Did the same on the demonstrator I tried. Hasn't caused a problem yet.
Have you tested the fluid in the system? It does absorb water over time so you should ask a garage to test it for you, it could be that it needs changing.
Yep me too... Took a little getting used to after driving my Tiguan. I think i did read something about this in a review... Maybe something to do with the weight of the car?
Not found it to be too hard to stop. I drive it differently from my MG3 and ZT though. I use the regen braking a lot but you need to preempt what's happening in front of you. The MG3 has the best brakes of the three!
