Busman
- Dec 17, 2024
- Ireland
- ZS Hybrid+
In the Hybrid version, I doubt you could fit it under the floor, even under the double floor with the floor in its upper position. After having had a annual S+ yesterday as a courtesy car, I can attest that you can definitely put a space saver in that, with the floor raised even a full sized one, no problem.So you can place a space saver spare wheel inside the boot or not?
Did you mean a HS+?After having had a annual S+ yesterday as a courtesy car,
Sorry, no a regular new ZS manual, non hybrid, now called in Austria ZS+ (because the old ZS is still on sale, and the hybrid turned from a ZS Hybrid+ to a ZS+ Hybrid as well). As that has the 12V battery in the front, there is a huge space below the false floor where the Hybrid modle has the 12V battery and styrofoam.Did you mean a HS+?
Do you mean just sit it in the boot . You can cut away some of the polystyrene so the wheel will fit under the floor . There’s a post I did on here showing it can be done .I got my Hyundai Kona space saver from the Wheel Shop and will be getting a one for my MG when I get the car. Unfortunately it will have to use the boot space but will be in a wheel bag. https://www.thewheelshop.co.uk/vehi...r_vehicle-year=2024-present-day&searched=true
There's a battery under the removable boot floor of the MG ZX hybrid.Do you mean just sit it in the boot . You can cut away some of the polystyrene so the wheel will fit under the floor . There’s a post I done on here showing it can be done .
Yeah, mine's too, but they managed to leave space for a space saver …just ..There's a battery under the removable boot floor of the MG ZX hybrid.
Could have been a lot more if they had moved the 12V battery elsewhere and all the stuff under the polystyreneI found your photos of this, I haven't got the car yet, and didn't realise how much space there was. Thank you.
