jondebi
My MG3 Hybrid+ has started making a high pitched clicking type noise intermittently inside the cabin. Does anyone have any idea what might be causing this?
Hi jondebi. I had the same screeching noise in the early days of ownership. I'm fairly certain it comes from the speed camera setting in the SatNav settings. I can't remember how or where the setting is, but if you go into SatNav settings and try each option, you should find it. AitchThere are cameras all the way on my journey but it only goes off in the one place. It's not the same sound as the other bongs. Thanks for your answer I will turn off all the alerts in the navigation and see if that works.
Thanks I will try this in the morning.Hi jondebi. I had the same screeching noise in the early days of ownership. I'm fairly certain it comes from the speed camera setting in the SatNav settings. I can't remember how or where the setting is, but if you go into SatNav settings and try each option, you should find it. Aitch
