MikeW
Hi
Thought this may be useful if anyone gets multiple system faults come up after a 12 V battery disconnect "reset". I had a "radio module disconnected" fault come up on the infotainment system. Tried the infotainment reset method, didn't work. Then disconnected the neg 12V battery leg for a few minutes. Radio then ok but multiple system faults appeared. Tried another 10mm spanner 12V battery reset. Still had same faults. Spoke to my dealer and he told me to turn the car on, don't drive but do a full right lock on the steering wheel, then full left lock ,then wheel back to centre. This cleared all the faults. Apparently it's a standard reset procedure after disconnecting the 12 volt battery. Hope this helps somebody. Apologies if this has been posted before. Also can highly recommend Unity MG, always brilliant service.
