hojnikb
- Dec 30, 2023
- Slovenia
- MG4 (2022-2025)
There's couple of things wrong with your method;
First as noted before; your battery doesn't actually have 77kWh of usable capacity. The actual value when new is 74.4kWh.
Secondly, the usable capacity also includes bottom buffer (which should be a couple of kWh on this model). When GOM says 0% it's not actually 0%. You need to drive the car until it shuts off to actually get the "full" capacity of the pack.
Batteries also lose it's usable capacity thru heat, as they have internal resistance thats more than 0ohm. So if you have 74.4kWh nominal, at for example 0.5C rate, the actual energy you get out is maybe just 73-73.5kWh and else is lost via heat.
And the last point; Are you sure the kWh/100km meter actually accounts for all power usage in the car? If not, your calculation will again be skewed. To get the most accurate value, you'd have to charge to 100%, balance and then discharge the pack via external means and count the kWh going out. This would be irrefutable evidence, that battery capacity is not correct.
But i suspect everything is ok and your methods are poor.
