John1941
- Feb 28, 2024
- Pembrokeshire
- MG4
Can I set charging times in my MG4 XR to take advantage of night rates?
What EVSE (charge point) do you have or are you using the 'granny' that came with the car?Can I set charging times in my MG4 XR to take advantage of night rates?
Or worse, you have a timer set to stop charging at 3pm (for Winter solar charging), and you're at a shopping centre and start a charge at 2:55pm. All looks good. I take my time shopping, and come back to find it's not charging, and in fact I only had 5 minutes of charging! ??Otherwise when you are away from home and trying to charge it won't do it outside the chosen times ?
Can you access the settings if you take your phone very near the device?Thanks for replies. Problem is not a dumb charger at home but it won't pick up wifi from my router despite using boosters, stone walls in the way. In-car timing may be the way but I don't find how in the downloaded manual.
I do it on the Ismart app.I have the MG4 manual downloaded but cannot find a reference to setting charging times from within the car.
The issue of connecting the charger (Pod Point) with wifi is a bit more complex. The connection appears intermittent. It works when the Skoda Citigo is charging but very occasionally for the MG4. I suspect that the router signal is marginal and the larger profile of the MG usually blanks off the signal. There is little scope for changing the position of the cars when charging.
I will persist with positioning the wifi boosters but cannot have them outside in the rain!
I thought the same except recent very early airport trip Car was set to scheduled timed charge (dumb charger) and I used iSmart app to start charging (at home), outside of the schedule which surprised me it worked, don't know if it can be done away from home as don't charge very often on AC 7kW chargers and have read DC chargers will charge anyway even if scheduled charge set but not tried this.If you do use the car for scheduling then don't forget!
