richlove
- Feb 27, 2023
- Woburn, Bedfordshire
- MG4 (2022-2025)
Looks mint ?? thanks for taking the time to uploads pics, much appreciated
It's a snug fit. Used the hairdryer on it to get the glue up to temp as its a bit chilly down here today. Stuck well first time, no hassle ?Looks mint ?? thanks for taking the time to uploads pics, much appreciated
Do you think it would come off with not too much hassle/damage, if need be?It's a snug fit. Used the hairdryer on it to get the glue up to temp as its a big chilly down here today. Stuck well first time, no hassle ?
The interesting thing is that it got here in one piece. It was in a single bubble wrap envelope, no additional packing - managed it though
Hope so, probably be a bit fiddly though. I'm using it to protect the piano black from scratches.Do you think it would come off with not too much hassle/damage, if need be?
Pretty sure it would come off relatively easy, warm with hair dryer, gently prize with a plastic lever. Any glue that may be left on, WD40 should do the trick. ??Hope so, probably be a bit fiddly though. I'm using it to protect the piano black from scratches.
I'm hoping if need be I can get it off without creating a bigger mess than if I hadn't put it on. Only time will tell.
Olive oil is great for removing residual glue/sticky stuff and a bit more gentle on the plastic
Popeye?What do you use to get the olive oil off?
Hey! Only joking!?
Sticky stuff ? ?What do you use to get the olive oil off?
You must have money to burn. Have you seen the price of olive oil especially as there's a shortageOlive oil is great for removing residual glue/sticky stuff and a bit more gentle on the plastic
