Trophy Dealer Questions
drivethru
London
Hey all
I'm due to pick up my trophy soon from the dealer.
I wanted to ensure all of the correct updates, recalls and fixes are undertaken before I drive away.
Can somebody help me with sharing what I should be requesting please?
There is no way to check if the updates have been done, you just have to take your dealers word for it. The only one you can check is the infotainment software version but although the latest version is R33 it doesn't seem to be much different to R24.
Walk round the car checking for damage, check the panel gaps, take a plastic bag to kneel on if it's wet and look underneath at the rear under-tray. Check the interior and inside the boot for the charging cable.
The dealer should help you bind the car to your phone so download the iSmart app before you go and set up your account but use you email address for the confirmation code not your phone number. When binding the car the app will ask for a pin number. Put whatever you like in but remember it. I suggest you write your app password, pin and the email address you used to set up the app down.
This contains tips such as Ian states
Oil Leak/new breather fitted
Undertray warped
Body trim alignment
No loose exterior plastics
TPMS alert not present
No dash warning ( such as activate messages)
Seat fabric in good order
Light Clusters in good order
Cable(s) provided
Car can "bind" to app
Bluetooth connects
Check 12v battery tightly connected
All available software updates installed
If you can do a drive around the dealership area to check for (before going home)
Wind noise from the drivers side only at ~ higher speed
Rattle in glove box area
Windscreen washer effectiveness
Steering vibration at higher speeds
And later
Light beam/reach in darkness
Keep an eye open going forward
Loss of power under hard acceleration, low soc
Drivers door button to unlock the car functions
Leaks/poor seals reported on windscreen/door seals limited reports
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
