Type 2 charging failure!!
BowrieMG
Forfar
MG ZS EV
Hi, I recently had some issues charging with the type 2 cable from a couple of charge place Scotland chargers and one pod point at Tesco’s.
The car charges fine at home using the same type 2 cable but failed after five minutes on the PP’s one, there were multiple fails on the CPS ones at two different sites. As the car charges fine at home with the same cable I was discounting the cable and the car itself but I am now starting to wonder if there may be an issue with the car or if the issue may well actually be with the PP & CPS chargers?
Any feed back is welcome, as I ended up having to call the RAC to take me to a charge point which worked but this was using the CCS at a Lidls which is run by PP…
I take it your logging in to the charger as they normally give 5 mins grace to give you time to confirm charge?
