Andrea88
Hi Everyone,
I need some help with type2 cable charging issue. It has started about 3 wks ago, if I`m charging my MG4 Trophy at work with the Type 2 cable that came with the car, the charge stops randomly between 57-65%. It doesn`t ,atter if I started from 20% or 40%, it`s always in that rnage that it stops. I have restarted it in the app and will charge for another 5%ish then stops again.
We have over 10x charging points at work (7kW), and tried several of it and noticed the same issue.
It does not happen on fast charging or at home charging with the granny cable.
I`ve checked and do not have a scheduled charge in place or a limit of % set up on the car.
I had the car for 2 years and only started to this. Could it be the cable faulty or is a CCU fault?
Thank you very much
Thank you very much
