Tyre Pressure Monitoring System Failure MG4
chadcombe
cheltenham
Afternoon all,
Had the MG4 Trophy L/R for 3 months now, love it 90% of the time, perhaps a common statement ? 10% that I don't are the usual software glitches/quality of interior plastics etc. I understand and can overcome these shortcomings most of the time. Recently though I have had a " tyre pressure monitoring system failure..consult manual" dash warning. If I stop , restart and carry on the warning disappears for a while then returns, sometimes followed by a warning of low pressure in either the left or right rear tyres. Following advice I read on here I've let air out, re-inflated in the hope that it may be a "stuck" sensor. This hasn't worked. The car is a 31/12/22 so still under warranty. Firstly, has anyone else had this issue? Second, do you think this is covered under warranty ( before I call the local dealer) . Always best to hear others views first I feel before I totally trust the local dealer (!). Appreciate any input....KR
Are you inflating the tyres enough? I'd recommend 38 psi all round. If yes and the issue still occurs, then it's either a software problem or one or more of the pressure sensors is faulty.
I looked in the warranty document and couldn't find any mention of pressure or sensor, so (to me) that means they're warranted for the full 7 years.
Thanks for the swift reply. Just checked and they are ( cold) 2.5 bar which is 36.2 psi. Worth a try at 2.6 I guess( 38 psi) as you suggest. I would understand that if it was a low pressure warning message but it's a pressure system failure message i'm getting so I can't really trust anything it says if it's faulty. I have checked and the pressures are actually as shown on the app/car so it appears to be working ok. Local dealer visit I feel..
Actually, I have the same error in my car (in my case, I get a warning that the entire system has failed). I’ve got a service appointment scheduled for next week — they will replace the sensor. What’s weird is that in my case, the error only appears after driving at autobahn speeds (around 120–130 km/h) for about 10–12 minutes, and it only affects the left rear tyre. I think it’s either the sensor in the wheel or — what I could also imagine — that the TPMS uses a four-antenna design (with one antenna in each wheel well). Maybe it’s just a misplaced antenna. Unfortunately I was not able to find any information regarding the tmps anywhere online so it's just a guess.
The sensors have a battery in them (usually a large button battery potted into the sensor). When the battery gets low or dies - the sensor is toast as you can’t replace the battery.
They transmit data on the same frequency as the remote central locking. The car knows where each sensor is as the serial number of the individual sensor is told to the car on installation hence if you rotate tyres, it won’t know the new/actual position without an update. It sounds very much like sensors are dieing. I believe they are only covered for a short time on the warranty.
The autel range of tpms kit supports the mg4 (autel have a generic sensor which you prepare with their tools to behave like an original) and there are a few options to replace (their generic sensors are cheap). They can be cloned from originals if you know the serial number or with their higher end tools new sensors can be created and then the serial numbers entered into the car so it knows what to listen for.
My car is from September 2023 and I have the issue since I took delivery in April this year. So I don’t think that it is the battery in my case. Sensors are like 20€ a piece in Germany but I was told that they will try to change it under warranty. Will post an update below when the car was in the shop
Seems a bit backwards in this day and age for them to need coding to the car for which wheel they are on. The car should be able to work that out for itself like many other brands can.
It requires extra equipment to do that hence costs more. The way they do it is fit a transducer in 3 wheel wells (you fire a few kHz signal maybe 100khz can’t remember into the TPMS sensor and it replies with its pressure, serial number etc on the frequency of the central locking). It can command the 3 sensors to respond and by elimination the other signal it sees is the 4th as they transmit at intervals when the tyre rotates. £££ saving to just preprogram the sensor IDs to the car.
Vauxhalls have a learning mode where you go round in order and provoke each sensor so it can learn. The cars that can learn without any additional kit or pre programming will generally only tell you a tyre is low but not which one - like on a Kia I had.
Car booked in soon to be looked at , I'll update when I know the outcome. Fingers crossed it's under warranty..
I got the same yesterday. I did have the tires inflated to 2.5 bar front and 2.8 rear, but a combination of pumping them up in summer in Greece and driving them at 11°C in the Netherlands they started showing 2.3 front and 2.6 rear.
It was a warning that made me route to the nearest gas station, but 10km before i reached it the system showed the front left tyre at 2.2 bar and then immediately followed with the TPMS system failure, which freaked me out.
Turns out the tyres are all good and the TPMS is not stable, so instead of saying something like the warning is now becoming a danger since 2.2 bar is way to low, it actually claims the TPMS failed.
But, i did stop, check the tyres and drove slowly to the gas station, and after inflating back to 2.5 front and 2.7 rear, no longer complaints at autobann speeds in Germany. Only now the tyres show 2.6 / 2.8 bar.
Just got my car back from MG and they seem to have fixed it. As of right now it also seems that the warranty is covering it.
Update: Back from dealers. The NSR sensor was faulty apparantly. Replaced. They have inflated tyres to "correct" pressures : 2.8 all round except NSR now at 3.2 ! It may settle down I suppose..At least I didn't get any warning message on the drive home. Will monitor..
Why would they put 15% more pressure in one tyre than the other 3, it makes no sense. :(
Front and rear tyre pressures can be different, but the two fronts should always be the same as each other, and the two rears should always be the same as each other.
Totally agree, i'm just living in world of hoping it will settle, real pain having to let the car go all day and 45 mins each way. Courtesy car ? of course , no problem...for £30.
I once picked up a Brand new Qashqai and the front o/s tyre was inflated to 75psi, exactly double the 38psi recommended! The inflation process appeared to have been done twice.
Technicians are human and make mistakes. It always pays to check.
So..update. Bought/used new pressure guage today on cold tyres. Confirms that 3 tyres are 2.6 bar ( ish) but the one with the new sensor is 2.95 bar. I'll trust the guage as it's clearly showing the LNS is over-inflated as suspected from the dash reading and I'll adjust to match the others. Interestingly (!) I've checked my software and I'd taken a screenshot ( attached) about a month ago showing R29, just checked and it's now showing R24 ( attached) Why would a dealer retro-install the software ? I did ask them to look at the temperature discrepancy ( i.e on 25/26 degrees to be reasonably comfortable when my old Merc climate wuld be 21 all the time ).maybe they altered the software in looking to fix this ( which they haven't ). Apologies if this should be a new thread but I thought it may be connected to the tyre issue on this thread.. thoughts most welcome please....
It's a wonder the tyre didn't explode at 75psi, most car tyres are rated at max pressures way below that.
    Votes: 1,060 77.7%
    Votes: 207 15.2%
    Votes: 99 7.3%
