Tyre Pressure
Rstor
The Midlands
HS PHEV
Does anyone know what type pressure is needed for a fully loaded car? The user manual only states unladen vehicle.
Types are 235/50 R18
Any help appreciated
Check inside the doors there are some plates
and on the doors under the lock. There is a plate somewhere on the car but can not remember where it is, also try inside the fuel flap. Will look in the morning if you do not find it.
Left front door just under the lock.
Thanks, much appreciated
I don’t think I’ve ever had a car where pressure wasn’t different with/without load, but at least I have the answer now
If you do adjust the pressures, the TPMS will still come up as a fault. I had to drive around for about 5 minutes after readjusted then stopped and restarted and TPMS was quite happy!
