unable to turn off lights
thowi02
london
MG4 SE SR
After parking car and locking doors lights flash and stay on. Checked all doors closed and tried again same problem.
Anyone any ideas?
Are 'auto lights' switched off, for you to switch lights manually? If so, move toggle on indicator stalk to off?
New to me this MG lark, so I may be way out on this!
I had similar happen to me but for the life of me I can’t remember what the lights were set to when I got out & locked the car but when I got back in, switched the lights to auto ( so you see Auto On on screen ) got back out, locked the car & lights turned off
If it’s still happening I’d suggest
Get back in car, pedal on brake so it goes into Ready mode
Switch the lights over to Auto, if it says Auto On, get out lock the car
If you hot the switch & it says Auto Off, switch it again until you see it say Auto On, get out & lock car
Hopefully this should do it, good luck
Anyone any ideas?
With a bit of trial and error I'm sure you'll find out whats going on and then you'll know in future. The above seems the most likely answer. Is it just the front DRL's that stay on ? or are the rear lights on too ?
I once dropped my keys on the car floor (without knowing) and wondered why the hell the car would'nt lock using the button after getting out 😁. It took me a while to realise my keys were'nt in my pocket and the car knew they were still inside the car !!
    Votes: 501 79.4%
    Votes: 84 13.3%
    Votes: 46 7.3%
