dgs99
Took my first long range journey away from home this week. Most of my trips since buying the car have been within the max range, so I have always been able to return home to charge back up. Recent journey to Watlington, Oxford meant had to use a rapid charger for the first time. Pulled into Leigh Delamere Services M4 eastbound and CCS charger wouldn't work, said a communication error. There was an electrician in attendance on the adjacent station and he said try this one instead.
That wouldn't work either and he cursed them both saying he has a regular call out to them as they always get wifi connection problems there. No problem, Zap Map said I should get to my destination with 20% charge remaining, which it did and was a very accurate estimation. On my return journey, road closures meant I had to go on a detour but my nearest charger was at Lidl, Wallingford, which I got to with 8% charge left in the tank. Luckily this 50kW charger worked OK and I was on return journey home within the hour. How low can you go with the residual charge before the car comes to a stop?
