BugEyed
Not all of these meet the requirements for connection to the UK grid. Check before using it.If you have a solar/battery system it is possible that your system may have an AC Generator input. I guess this could be used?
Usually, the generator input won't connect to the grid, only to your house loads. I suppose that doesn't necessarily prevent some authority from trying to stop you.Not all of these meet the requirements for connection to the UK grid.
I can second this - exactly the same experience with our ZS EV when camping recently.In conclusion:
V2L does work without powering up the car to READY State, so DRLs do not have to be on and the car can be locked.
There is a drain on the 12V battery when V2L is enabled in this way - It appears that the software in the car does not look after the 12V battery when V2L is active and car is off and it may flatten the battery making it impossible to start the car if V2L is used for extended times - suggest to give yourselves two hours use before at least using the app to connect to the car.
Using the App to quiz the car will revive the battery. However, there is a momentary loss in the output to the V2L when the App connects to the car.
Note that the drain on the 12V battery is not related to the power draw on the V2L connector. Merely having the V2L enabled causes the drain in 12V battery.
If the car is on and in the READY State then the 12V battery is not an issue.
If you connect to the VTL adaptor using a 2-way mains adaptor, could you not also run a charger to keep the 12v battery topped up?Just to add (as it was us that had to call the AA to the campsite):
When V2L is connected and the car is powered down (yes, it works fine) - there is a 2 amp load on the 12v starter battery. Nobody who has looked at the car can figure out why or what this is for, but it is there nonetheless. Just bear in mind that if you plan to leave the V2L plugged in for any length of time, the 12v battery may take a beating! The only way we managed to get round this was leave the car in Ready state (DRLs on).
This does somewhat limit the usefulness of V2L (we only intended to use it when camping to avoid paying for electric hookup).
I have a trickle charger so will try this.If you connect to the VTL adaptor using a 2-way mains adaptor, could you not also run a charger to keep the 12v battery topped up?
Yes, you need that small puff of energy from the auxiliary battery to pull in the contactors, perform pre-charge, etc. But as soon as you do, you have the DC-DC available to replace that energy and more, and hold in the contactors via energy from the main battery via the DC-DC.In order for the DC-AC inverter to start working, voltage is needed to start it and maintain it in working condition. so use 12V battery.
I was just about to ask this question, when @aleks57 beat me to it .I have a trickle charger so will try this.
I suppose it's possible, but I really highly doubt it. For all the world, it looks like the computer monitoring the type-2 port is just checking for a yes / no answer: is this resistance indicating V2L, or is it indicating a charge cord amp capacity? Having a "yes but don't charge the auxiliary battery" answer just makes no sense, at least to me.I haven't seen anyone get an official MG "discharge gun" yet, so wondering if the resistor could be "wrong" and the reason the 12V battery is not being charged?
The issue is the software in the car, not the resistor in the cable.Caught some of the MG4 podcast yesterday and one bit that stood out for me was when Miles said that the MG V2L has a different resistance to other V2L so you cannot use the Kia or Hyundai adapters for example. Is the 470 ohm resistor correct? I haven't seen anyone get an official MG "discharge gun" yet, so wondering if the resistor could be "wrong" and the reason the 12V battery is not being charged? Wishful thinking I suppose and suspect the reason is just design as usual!
Maybe consider purchasing one of these for the future ?.Won't quite power the kettle unfortunately.
Already got one, just got it out of the garage.Maybe consider purchasing one of these for the future ?.
Handy 1 litre kettle rated at 1000 Watts, ideal for use on the move with our V2L cable as well !.
Amazon product ASIN B06XC1RQFV
Boom - Sorted !.Already got one, just got it out of the garage.
Would appear this chap did some testing on this subject in this video in the other thread.Caught some of the MG4 podcast yesterday and one bit that stood out for me was when Miles said that the MG V2L has a different resistance to other V2L so you cannot use the Kia or Hyundai adapters for example. Is the 470 ohm resistor correct? I haven't seen anyone get an official MG "discharge gun" yet, so wondering if the resistor could be "wrong" and the reason the 12V battery is not being charged? Wishful thinking I suppose and suspect the reason is just design as usual!
