Gomev
Distinguished Member
Leeds
Not an MG
Does anyone have any experience of these. I'm considering replacing my EVSE ('charger') and have seen these at a 'cheaper than others price' of £745 tethered or untethered fully installed by Smart Home Charge' They are also Octopus Intelligent Go compatible.
No experience of those, but... nearly £400 (min) for installation sounds a lot, if you already have up-to-date wiring in place for your current charger. May be worth looking into whether buying just the charger for £384 and getting a local sparky to screw it on the wall and connect 3 wires could work out cheaper - just a thought.
Just looking at their charging cable warranty :ROFLMAO:
Good point @Alb...
Note also that the unit itself is only IP54 rated, rather than the more common IP66 rating.
The 'water ingress' part (second digit) of 4 is only splash protection... "Protected from water splashes from any direction, like light rain or spray. Best For: Indoor use with occasional moisture or outdoor covered areas"
Good point @Alb...
It says IP55 in the FAQs. so dust protected and water jet proof. Maybe it reported differently in different places ??
Regs have changed since I had my current one installed in 2020. I have a matt:e box as they couldn't drive an earth rod in anywhere. I suspect other than the cable going through the wall I would need a whole new installation.
Undecided as yet, I am still working on making my current app work again.
But, according to their website
The Vchrgd Seven has built-in earthing protection, which avoids the need for an earth rod to be installed at your property.
So the lack of an existing earthing rod should not be a problem for you.
Sorry I obviously didn't make the point of my post well enough. The point was that I would probably need a complete re-install, as opposed to just being able to stick a different box on the wall and reconnecting a few wires. This would include removing of the matte:e and other stuff needed for the newer regs.
I think most if not possibly all newer 'chargers' have the built-in earth protection which mine hasn't.
That is quite old, dated 2024, I wonder if that maybe refers to the previous version the 'Seven' as opposed to the new version the 'Seven Pro' ?
I also found this which shows IP55 !
I think clarification is needed.....I have sent them a query.
Fingers crossed they have improved its rating.
Good idea to question it. FYI, the pdf I found came from this page about the seven pro..
a little way down is the links to the docs..
