Vehicle control fault
redwood98
Age
23
Bedfordshire
I charged my car to 100% last night, got in it today and a vehicle control fault error came up along with something about the hv battery and acc not working. The hv battery error and acc error have gone but the vehicle control fault one remains and it tells me to take it to an mg service. Anyone know what I should do?
Doing a 10mm spanner Ctlr-Alt-Del procedure would be my first port of call. AKA disconnect 12V battery, wait 5 minutes and reconnect it.
I am doing that now, these are all the errors I am getting if anyone is able to help in the mean time.
I now have more errors since disconnecting and reconnecting the 12v battery. I have tried clearing the errors via OBD and locking/unlocking the car but neither have worked.
Yes ... turn fully left, fully right then return to the centre.
You'll also need to reset the window controls ... press and hold fully down to open, when open keep holding for 10 secs, then lift and hold to close, when closed keep holding for 10 secs. Repeat for each window. (From memory)
Thank you, this fixed all of the errors except the original one I had which is the vehicle control fault
I’m not entirely sure I left it awhile after the battery disconnect and reconnecting then did the steering wheel thing to reset the errors, vehicle control fault was still there but I cleared the errors a few times using a obd2 Bluetooth device with an app and eventually the error disappeared, (probably the spanner my dad accidentally dropped in the bonnet that fixed it 😂) I drove it round a bit and it didn’t get the error back but it’s possible it could come back so I’ve kept my mg appointment for now as it’s for just before Christmas.
Although I don't have this problem anymore, my car is still scheduled to go in on the 23rd. Will I be charged since the error is gone? My brother found current error codes when he checked my car which is why I still want them to check it as those error codes are for the back sensors and my friend as stopped right up behind my car and the sensors haven't gone off so I do think there is a problem with them. What should I do? Should I ring up MG and tell them that the problem has changed or just let them know when I get there and will they charge me? Also the original problem came up when I charged to 100% and I haven't done that since so it might happen again when I do.
I'd also like to request they update my software of the car too as it's very old, how should I do that?
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
