Mgkev
Just returned from a 20 mile each way journey with mixed driving and A/C on. Did this at 4.1 miles per Kilowatt. This car is so efficient at local driving conditions.
You may find that when you are on faster A roads and the motorway you'll get more from Kers being set at 1 and coasting more than you can get back from regen (If not using MG Pilot/ACC)I did a 170mile trip (mostly on A-Roads and Motorways) from near Leeds to Chelmsford and got 3.6 m/kw at mostly around 60mph few days back.
But I was sort of trying the 'hypermile' thing with AirCon turned off+Eco Mode+KERS Level 3 and following trucks whenever possible.
I noted AirCon/Heating has a massive impact on Range.
What settings did you have in your drive ? and what was your average speed ?
I got 4.2 miles/kW on a 120 mile trip yesterday outside temperature was a steady 12 degrees. Mixture of A and B roads plus some light town centre driving at 20-60 mph overall. Normal mode with region at 3 is where I leave it all the time. My accrued mileage about 1500 shows average of 3.9 miles/kW. Interesting to see how the different levels of regen might affect the efficiency although my driving style is to 'feather' the throttle to reduce speed as necessary which may not produce the full regen of that setting? I think this needs some experimenting maybe.Well, I got 4.8KWh yesterday on a journey, first time ever and thought I'd try driving economically. I was surprised, best I've seen before that was around 3.5KWh. I was in eco mode, KERS 3, no aircon/heater and had the sunrook tilted up and driver's window croacked open a tad. Was a mixture of town driving and faster A roads.
Interesting point about KERS 1, will try that....
Just give it time and you’ll slowly improve, but it’s cold and that will make a difference as well as if your area is hilly of flat.Makes me wonder what I'm doing wrong... I'm getting 2.7kWh
Mark not just you mate I'm 3 years in to ev ownership and this car is so inefficient even when you're trying ....65 mph on the motorway with heating on low and in eco will struggle to get 2.6 whereas in the 40kw zoe before it would easily do 3.5.Just give it time and you’ll slowly improve, but it’s cold and that will make a difference as well as if your area is hilly of flat.
My average over 12500 miles even with the cold is 4.1 KWh, it was 4.3 before the winter weather.Mark not just you mate I'm 3 years in to ev ownership and this car is so inefficient even when you're trying ....65 mph on the motorway with heating on low and in eco will struggle to get 2.6 whereas in the 40kw zoe before it would easily do 3.5.
I honestly think that for a car with 42.5kw battery it should be able to do at least 140 miles at 65mph.
The problem I have with this car is that you cannot drive it like a normal ev in that if you want to get 3kwh or more you have to crawl up to your desired speed.... If you're getting over 4 kwh and you're driving it without thinking ie crawling up to say 30 mph then there's something wrong with a lot of these cars because not many people are getting above 3 kwh.... The zoe it replaced you could drive like a normal car and smash 4.5 kwhMy average over 12500 miles even with the cold is 4.1 KWh, it was 4.3 before the winter weather.
Car | Summer Range | Winter Range | Weight (unladen) |
Kia Soul 30kWh (HP, 16" tyres) | 4.5-5kWh = 135-150 miles | 3.5-4kWh = 105-120 miles (heating set at auto 20C) | 1580 kg |
Nissan Leaf Tekna 21.3kWh (HP, 17" tyres) | 3.5-4kWh = 75-85 miles | 3-3.5kWh = 64-75 miles (same as above for heating) | 1505 kg |
e-Golf 32kWH (no heatpump, but heated seats, 16" tyres) | 4.5-5kWh = 144-160 miles | 3.2-3.7kWh = 102-118 miles (heating set auto 19C + heated seats) | 1615 kg |
MG 42.5kWH | 3.2-3.7kWh = 136-157 miles | 2.4-2.9kWh = 102-124 miles (heating set to three red blobs, fan on 3 + heated seats) | 1566 kg |
