mlsaksiri
Banned
I need to remove my ZS EV charger from the wall to get it repaired. I can't see any obvious lock to open the case itself to get to the interior. Can someone help me with instructions on how to open up the case?
Me neither but I suppose you haven't been to Thailand either ?I've never seen an MG charger.
Tesla Bjorn has the same charger installed at his in-laws house in Thailand.That charge point isn't used in the UK so the majority of members here will not be familiar with it. That said, there are a few members from your country so one of them may have the information you seek.
Make sure you safely isolate power before you open anything up![]()
Thank you - after all these years, this was a life saver.....or at least marriage saverThank you gentlemen for answering my distress call. I've figured it out and have attached a self-explanatory set of pictures here for future reference. The trick is to be able to insert an 8mm wrench in the back of the case and loosen the screws gripping the hanging plate enough so that the case can be lifted up and out of the slots. The charger seems to be the weak point in MG's EV. OTW I have been totally happy with the car itself. This charger is the 3rd one and lasted 2 years. The first 2 did not work in the initial installation and had to be replaced by this one. I'll be taking this to an independent EV charger service shop and will give a report later. Thanks again.
