Warning lights galore - Any advice?
have installed a 12 volt battery monitor to the battery.
Something like this is brilliant for you to look back and see when your car actually charges the 12v battery I will definitely fit one when my car turns up hopefully the car will charge when left dormant a few days but in till I see proof I am a bit sceptical
The iSMART app shows Voltage Level of the 12V battery on the Status page.
At rest, my battery state is around 13 volts.
Just turn the car off for 15 mins then restart. Should be okay.
As these messages are related to centre screen suggest you try power the car up and hold the bottom left button for 10 seconds to reboot the screen.
If this does not work then try holding the start button for 30 seconds.
The important thing when powering up the car is to let everything get to a good condition before selecting Drive or Reverse.
Just to say that I have had this a couple of times where I have “rushed” the car during the start up process and driven the car with no problem. The “safety” features will not be enabled, but the car will still drive. After parking the car up and returning to it, all was fine.
If all else fails, disconnect the 12 volt battery for 10 mins or so then re-connect. If that doesn't reboot it's of to the dealer :) Cheers - Greg Electric Car Australia YouTube Channel
