Warning Signal of Battery?
rayland
TA1, Somerset
Hi Guys,
I had just driven My car for 3 days, While I start my car, sometimes it will show a below Warning.
After I turn it off and restart, It works again.
What should I do?
How can I find the MG Authorised Repairer?
Many Thanks!?
Press start button without putting foot on the brake, you will see a yellow led press it again and it will turn to green . Then look at you reading for your battery. If it's 12.v . It's needs Charging, 12.4v it's half charged . 12.9v full charge. When you drove it for three days did you use your Aircon or heater cos that's what drains it . Or parked up with the car in the Ready position. I've been told to charge it you can sit in the car with Ready position on and it will put a slight charge on it after half an hour but don't use Radio, Fan, etc
Sorry I meant parked up not in the Ready position and switched it on without pressing Brake . That can drain it cos you using your 12v battery that's not in ready position,so won't charge it.
