Water leaking in on passenger side mg5
Harves
Newcastle upon Tyne
Hi, Can anyone please help I’ve got a MG5 LR 2023 it’s done 35,000 miles and over the past couple of months I’ve noticed water on the rubber mat on the passenger floor , it seems to be dripping in underneath the glove box , I was wondering if anybody else has had this problem. The problem is definitely getting worse I don’t know if it’s the window screen that’s leaking or possibly through the bulkhead. Any information would be greatly appreciated.
My guess would be that the air conditioning drain pipe is blocked and it is overflowing into the car. Probably worth taking it to the dealers unless you are comfortable crawling around under the car. If that is the problem then you'll want to get it sorted before the weather warms up - its amazing how much water AC can produce.
Thanks for the reply I understand what you are saying but if I don’t use the car say for a day or two I change the towel I put down on a daily basis without using the car but thanks again
