ajw1100
- Sep 2, 2021
- Location
- Hertfordshire UK
- HS PHEV
Title sort of says it all, but rather not use ebay......
14x1.5 according to this, which is the same as most other MGs.What is the correct wheel nut size for a 2025 HS Plug in car?
It'll probably be 17mm, but if you're after a wheel wrench, one like this will cover all wheel nut sizes.14 x 1.5 may be the thread size. It is the cross the flats of the wheel nut I am asking for. As I see there is no wheel tool to remove the nuts in removing the wheel and tyre.
I'd be a little wary of that, the ad says "Fits all MGs from 2017" but gives the size as 12 x 1.75.https://www.ebay.co.uk/itm/197289920741?_skw=RRB000080E0&itmmeta=01K0CBDGFYF2NHS7FTP8C7GPEP&hash=item2def6548e5:g:0oIAAOSwQ3hoGdui&itmprp=enc:AQAKAAAA0FkggFvd1GGDu0w3yXCmi1dB4pv9sRLG8z1+B2G2IvOsO+R+rbpY+Me5eCr7YBPTO8aPaYO6QxF3gXAbChBZKADQFrw0h3zkU3P39YijdKiSkFZwQIn0a3MsC3y11wCi5X3ji0FYTmNWobq1UTrYSDTitpeCMg9OIn69i17pQgTKOrXkJTM9QzZkX1RUy+wA5lFM4gqHIzbhpRtLrIJCpL1+b5VouTjtL2BEb1LpVH+WYRe87IBAV0QQaZq2jDnjU2vaXuLBmyD5gVOeGM6zK1U=|tkp:Bk9SR5iItouDZg
seller offered me these for £36 genuine MG again.
if the part number quoted is correct then they fit my ZSEV and my S5 EV so should be fine for MG4 as Brown and Gammons lists that part number as MG4 compatible. I suspect they ve misquoted the thread sizeI'd be a little wary of that, the ad says "Fits all MGs from 2017" but gives the size as 12 x 1.75.
I've had 2 MGs and they were both M14x1.5
Yes you're probably right thereif the part number quoted is correct then they fit my ZSEV and my S5 EV so should be fine for MG4 as Brown and Gammons lists that part number as MG4 compatible. I suspect they ve misquoted the thread size
Ahh, it all makes sense now.Hi I have sorted it out.
First you have to remove the plastic nut cover. The plastic finger tool is in the boot. Nut size is a 17mm socket.
