Sabsack
Want to replace the wheels
What’s the specs want the widest I can get and the biggest with out rubbing.
Thank you. The difference between ET 51 and 41 is not so large indeed. I will trust wheel-size.com and will mount the 16'' rims from Audi Q2, which are 6.5Jx16 ET 41.
The 16" measure is in the official user manual as an option and the 6.5Jx16 is the adviced measure. The offset is not specified but I found the 41 value on wheel-measure database. The smaller value is probably just due to a smaller rim size (all the other MG models only mount 17, 18 or 19") to be sure that the brake caliper is not bathed. Thank youAh sorry didn't read your post. I was replying to the 1st post, which I've just realised is from July 2023
You might possibly struggle with 16s they could possibly catch the calipers, particularly the front. Only one way to find out try um. Good luck.![]()
I could potentially test this for you. My daughter has a VW New Beetle with 16" wheels. They are most likely the same size and offset as the Audi Q2. Wouldn't be until the weekend though. Wife has a Polo with 17" rims. All with the same PCD, so could be fun experiment. My wife would not be impressed if I nicked the BBS alloys off her car, and swapped them for the MG ones.Thank you. The difference between ET 51 and 41 is not so large indeed. I will trust wheel-size.com and will mount the 16'' rims from Audi Q2, which are 6.5Jx16 ET 41.
