Wiper blade size and hook type
it's all perfect guys! the MG ZS rear wiper blade fits and gives that extra cleaning coverage.
here's the link I bought from
Thanks for letting the forum know !.
I find it a bit strange why MG did not use the blade from the ZS in the very first place then, rather than designing a different sized blade and to produce one tbh ????.
Unless it was cheaper of course 🥴👍.
yeah, it's rather strange indeed. I don't see how much cost savings it will be for them when it's already a widely produced item though. or just them trying to find ways for owners to buy it through them - quite similar to how they started making the frunk for some of their older models.
but yeah, thanks again to the forum and Joningy for modding and trying out the size.
The cost saving I referred to is made because MG should just used the blade on the ZS EV.
Its a blade that they already are installing on another model, so no design / drawings / R&D required etc etc.
Plus they coukd have remaining stock of the blade from the ZS EV that they have not consumed ?.
Designing and producing a new smaller blade for the S5 does not make any sense ?.
It requires a new part number / cataloging, then stocking or ordering at every dealership, when the ZS EV blade will not only fit correctly, but it does a better job of clearing the rear window, due to its slightly increased blade sweep.
Why make a completely new smaller size blade for the S5 when the ZS EV blade is better ?.
Thanks for proving that the longer blade from the ZS EV is a compatible fit onto the S5.
I will be ordering one for our S5 👍.
ah yeah, haha. I was referring to the manufacturing cost savings since they reduced everything by at least 20% - 30%. which sounds like a big change on statistics but in actual dollars, probably small.
absolutely aligned with you as to how I don't understand why they did it in the first place too - perhaps in the name of change and "improvement".
Does anyone know if Bosch make a version of the 100% compatible ZS wiper blade and if so what part code is it please?
It’s a Bosch H250 I believe.
Readerly available on line or even at your local Halfords at about £5.50 ish 👍.
It can't be any smaller than the MG4 rear wiper. 😂
The S5 has exactly the same size rear blade as the 4 Clive haha. I found one on Amazon mid September, but if you recall, it needed a small mod to the slot the hook fits into.
"Rear wiper" sounds like a nursing home term for someone the manager isn't too keen on !!
