Xpower tyre size change 235/40/18
powerfulx
australia
Not an MG
So i am always chasing performance, old story. Dropping the side wall height on the xpower will change the gearing slightly and potentially get better acceleration, however i would also change to a performance tyre, even semi slick. I notice the stock tyres squirm about and most occasions TC helps out.
Dont get me wrong its already crazy fast.
This will of course impact other things like speedo, and potentially ADAS. It will also lower the car slightly and err make the guard gap even worse.
Im also waiting for either MG or aftermarket aero plates for the wheels, hides the orange callipers and increase long range to a degree.
Other options are under tray aero around the wheels, like my leaf has. Ride height of the x also impacts range to a degree.
On almost every car i buy, i remove stock suspension and replace with street coilovers.
MG went more for looks than eco , however would be nice to have more of both :)
all the effort probably not worth the cost nor the extra 2 mins at charger, but interested to know whats possible.
Very much Doubt you'll ever get Aero covers to fit the alloy wheels. If you really don't like the Orange caliper covers take them off or paint them. H&R lowering springs are now available for the X Power. ??
Ill probably wait on coils as i can adjust over time to where it handles best, but good to know those are avail
I got the dealer to take the calliper covers off before I collected the car. Could you simply switch to the standard mg4 wheels ? Would that achieve the same outcome ? Smaller, less resistance ? But would the bigger discs on the xpower fit ok ?
Hello Chris.
Thank you for your email.
Chris, I’m currently in conversation with Eibach UK, reference the MG4 as they are contemplating a Pro Kit for the chassis, which will not only give you better handling, but also a subtle lowering to enhance the looks of the car.
From past experience, H&R springs can be very hard and in turn you lose comfort from the ride quality, however Eibach do make all the springs with a progressive nature, meaning you don’t lose any comfort but added handling.
I would highly recommend Eibach, so if you could leave it with me for a couple of days, I will see if Eibach would like to go ahead. If not, we can supply the H&R etc.
I will be in touch.
What is full spec for XPower tyres and wheels?
MG are too tight to give me an X Power specific sticker!!?
Bottom specs apply.
So std wheels are 18”
Tyres are 235 45 r18 98W
Any idea about wheels offset/PCD ?
Sounds good. What does your insurance company say about all these changes?
Most easily obtained semi/slick is Nankang NS-2R
Toyo and Yokohama not found…
Michelin Pilot Spirt Cup similar but size availability for all alternatives may be an issue…
Having extra set wheels for semi-slicks is easiest option but more expense…
H&R dont currently supply them in the UK. I tried to buy a set. Their UK distributor is Euro car parts.
The springs lower front & rear by 30mm.
Alloy wise you would be best buying aftermarket ones for Aero. I will attach the fitting specs (believe theyre the same as VW/Audi.
Just to confirm @pjmmk post above :-
5 x 112mm bolt
Offset ET 51mm
Centre Bore 57.1mm
So Golf GTi and R wheels should fit OK, I still have an old Mk 7 Golf R alloy and intend to try it soon ?
From a standard MG 4 with 17" but the above info still stands :-
