ZS EV Battery confusion
MG ASH
Lancashire
Hello,
I Have a MG ZS EV Long range car. On the second year now and finding this season the battery lower than ever. It had a fault where on the 7KW charge it was only charging at 2.9 - 3.1KW . so went to MG they found a fault with the female Socket on the car and put a new one on. Worked ok back up to 6.9kw.
There is now a light on the same socket which stays on see image which stays on. There are 2 questions please?
1 - Is there a problem with the light on and does this mean the battery needs refreshing?
2 - Should the battery heater be on constantly 24hours?
look forward to any help.
Hello,
Just to advise. had this checked out and apparently it is a short at the back. They have ordered the part to replace. Note - it did not effect the performance of the car or changing.
hope some people found helpful
Thank You,
Just one more question on the heater.
When do i need to use the battery heater, just in winter and off in summer, or just when i charge the car?
People who are clocking up big miles on long journeys, tend to use the battery heater prior to using a rapid D/C charger.
Raising the temperature of the battery can increase the charging speed and get them on their way faster.
