Rubbish I’ve....cough....cough....done more.....The ZS EV top speed is 87MPH.
If you believe the marketing materials from MGThe ZS EV top speed is 87MPH.
Google maps ? I use that on a journey.I've seen higher than that indicated on the speedo, but unless you have a GPS speedometer you can't trust the dials
That was one of the first things I checked once I got the car. Always a good thing to know.I’ve found the speedo to be quite accurate - comparing with various GPS displayed speeds - e.g. carcam, satnav - it’s usually about 1 or 2 mph below the gps speed.
Below ?I’ve found the speedo to be quite accurate - comparing with various GPS displayed speeds - e.g. carcam, satnav - it’s usually about 1 or 2 mph below the gps speed.
Mine have always read above, the Priuses were up near the 10% over the GPS dashcam and those "your speed is" signs.I’m not sure but on most cars I’ve had the cars speedo is always a little below the gps speed reading
That's what I said.i’m not explaining it very well am I! I’m saying the cars speedo reads typically above what the actual speed is - I’m assuming gps is more accurate. Generally cars that I’ve owned show speeds that are in fact slightly above the actual speed. E.g car shows 30mph - gps 29mph - roadside camera display 29mph. Time for a lie down
