Thanks will sealThe tin worm will have a better feast now he's just scratched all the paint off the edge of the drain hole with his screwdriver.
A bit of Waxoyl or Dinitrol should sort it, I believe you can buy both in aerosol form now.Thanks for letting me know, will try sealing, or greasing
Waxoyl solidifies into a waxy coating when the solvent in it dries off, it also kills any existing rust.Sadly I'm not as optimistic as you are about that. Any surface treatment as thin as a slushing oil is likely to get removed by the road sh*te that gets washed in and out if such an exposed place. Frankly a thicker bitumen coating may be more effective.
You could of course go for something like this as the best of both worlds:
Underbody Seal
