pollenface
- Jan 10, 2023
- Location
- Perth, Australia
- ZS EV
12.1v indicates heavy sulfation, capacity loss, replace ASAP.
Hi, as others have said, try disconnecting the 12V battery, leave it for a few minutes and then reconnect it. It'll throw up a bunch of error messages, but they'll soon clear once you drive the car. It worked fine for me and I've had no further issues with it. You'll only have to disconnect and reconnect the 12V battery once and it should solve the problem. I hope this helps.I am leasing a new MG5 since December. We started getting these messages every day after 6 months. The 12V battery was replaced under warranty about a month ago. Now the same warning messages are coming back on a new battery. We use the car normally, don’t let it sit for long periods. I think it’s just a very very poor design. Something is draining the 12V but we’ve no idea what it is. I suppose we just need to keep a jump start with us and ignore it I guess.
You're most welcome. I'm pleased that's resolved it. As you say, best to monitor it. If you don't receive the error message, but still find the level has dropped somewhat when you check it on the display in the car, I believe pre-cooling the car from the app will get the 12V battery back up to 100%.Hi there, I did try this and miraculously after a flurry of every warning message under the sun it did indeed start displaying a full 12V charge and the 12V warnings disappeared.
So it's some kind of software/communication issue then I suppose.
Thank you, will monitor for now but hopefully that is indeed the end of it, because it is the most tedious issue ever.
Another top tip! Cheers.You're most welcome. I'm pleased that's resolved it. As you say, best to monitor it. If you don't receive the error message, but still find the level has dropped somewhat when you check it on the display in the car, I believe pre-cooling the car from the app will get the 12V battery back up to 100%.
When the car isn't driven, its 12v lead-acid battery gradually discharges until the voltage drops below a predetermined threshold, the DC-DC converter then turns on, recharging the 12v battery from the traction battery. Problems occurred because this threshold voltage was originally set too low, leaving insufficient charge on the battery to reliably run the car. It's my understanding that the SC052 software update addresses this problem by raising the threshold voltage, thus maintaining the 12v battery at a higher state of charge.I notice 14.7v while charging, 14.2 while driving.
This functionality has indeed been mentioned in MG5 marketing materials, but it was never implemented. In reality the 12V aux is only charged when the car is READY, charging or in Pre- Heat/Cool mode.When the car isn't driven, its 12v lead-acid battery gradually discharges until the voltage drops below a predetermined threshold, the DC-DC converter then turns on, recharging the 12v battery from the traction battery.
Thanks Mickey, on checking I've found you're right.This functionality has indeed been mentioned in MG5 marketing materials, but it was never implemented. In reality the 12V aux is only charged when the car is READY, charging or in Pre- Heat/Cool mode.
